oil leak..... help!!!!
Old Mar 23, 2010 | 02:45 PM
jdm27ef's Avatar
Default oil leak..... help!!!!
i have a 90 civic si with a6 bottom and y7 head
i have this huge oil leak next to the oil plug and it feels like the bolt is loose thread. Now what i dont know which one is loose thread the oil pan or the bolt. im loosing a lot of oil everyday. how can i fix this? do i need to get a oil pan or the bolt?
i searched i cant find any thread about this.
thanks in advance guys
Old Mar 23, 2010 | 06:02 PM
black0hatch's Avatar
Default Re: oil leak..... help!!!!
take the bolt out then put it up to your face and look at the threads on the bolt. if there good stick your head under the car and look at the threads on the oil pan. thats how you know whether you need a bolt or pan. just so you know it is common for oilpan threads to get stripped out from idiots at lube shops not caring. you can get a ghetto fix they sell drain bolts with little things that go up in the pan made just for stripped out threads.
Old Mar 23, 2010 | 06:03 PM
oh ya make sure its not just loose from someone forgetting to tighten it all the way. or missing the crush washer.
Old Mar 23, 2010 | 06:36 PM
JustOneOrTwoPosts's Avatar
if you are noticing the loss of oil everyday, it sounds like a significant leak. Try wiping the whole area down and waiting for oil to come out from somewhere. Or you can wipe it, drive it around the block, and then check. and do what black0hatch mentioned above
Old Mar 23, 2010 | 07:17 PM
Jockone's Avatar
Napa parts stores sell an oversized oilpan bolt if it is the pan,it is like a self tapper,buy it and screw it in ar if it is your bolt just buy a new one.
Old Mar 24, 2010 | 08:35 AM
jdm27ef's Avatar
ok ill do this after 3 months, cause i just got my oil changed like a week ago. I went to autozone and ask around i saw that thing where you have to drill on the oil pan and plug in a thread, is that what you talking about?
yeah i jacked my car up and wiped it and its leaking bad
kk thanks man
kaychi
Jul 9, 2008 12:10 PM
paawk2000
Jul 16, 2007 07:54 PM
ombl4
May 10, 2007 01:42 PM
MechEng
Oct 21, 2005 12:14 PM
megaman096
17
Dec 5, 2004 03:09 PM
