Engine light came on... when it wasn't supposed to.
Old Mar 23, 2010 | 02:41 PM
bleong3292's Avatar
Default Engine light came on... when it wasn't supposed to.
hey guys, im new to the whole tuning era, got myself a 2000 Prelude and i bought this fuel enhancer thing. it says to unplug the IAT sensor (intake air temperature sensor) and to tap into the wires with the supplied tool with the module.
I did this, and the engine light came on. Freaking out, i took off the module and plugged the IAT sensor back in.
The light is still on. How do i get it to turn off?
Many thanks,
bleong3292
Old Mar 23, 2010 | 03:19 PM
GlassJAw's Avatar
Default Re: Engine light came on... when it wasn't supposed to.
Reset the ECM by pulling the fuse under the hood, or disconnecting the Battery negative for 30 seconds - not sure if your stereo has security code or not, but it would be wise to know the code before you disconnect the battery
Old Mar 23, 2010 | 04:12 PM
A Blue Lude's Avatar
Do that (you'll need the code for your radio), and then throw that thing you bought in the trash.
Old Mar 23, 2010 | 04:21 PM
bleong3292's Avatar
Even if i had the code for the radio, wouldn't i still need to take it to a shop to use a reader and enter the code? might as well just take it there to get the engine light removed. I talked to my local garage, they said it would cost just $47-- to scan and remove the error codes.
Old Mar 23, 2010 | 04:41 PM
peacekpr's Avatar
$47?!?! Go to Autozone or something. They'll read the code free of charge. But before you even do that, reset the ECM as was suggested.
Old Mar 23, 2010 | 04:42 PM
Kronn 98SH's Avatar
https://honda-tech.com/forums/showthread.php?p=38252637
^^^^ Or do it your damn self? ^^^^
Old Mar 23, 2010 | 04:59 PM
bleong3292's Avatar
i called my local autozone... the guy i was talking didn't know jack **** and said i could buy a reader for $144 when i only have $110 max.
Old Mar 23, 2010 | 05:04 PM
Kronn 98SH's Avatar
See that post right before yours?
Old Mar 23, 2010 | 05:08 PM
bleong3292's Avatar
Yes i did. And the negative wire is off the battery as we speak. i took it off the hook before i read your post. But now, i have to go find the stupid radio code.... would anyone know where i would find it? i've tried the manual, there is a sticker on the inside of the glove compartment but there is a number 9 and a letter B in it. not sure how i would enter that in the radio. but oh well.
Old Mar 23, 2010 | 05:15 PM
GlassJAw's Avatar
From what I can tell about the factory stereo's its a 4 digit pin number that is entered by the 6 memory location buttons on the stereo itself.
I'd personally read the ECM code myself using the link Kronn stated
Then Reset the ECM
**edit.... damn It's hard to type and take orders whilst at work....
Old Mar 23, 2010 | 05:40 PM
bleong3292's Avatar
Then Reset the ECM
Where would one find this 4-digit code...
i did that jump thing with a paper clip. and checked the chart to be my IAT Sensor, to which i knew that that was the problem before hand.
Old Mar 23, 2010 | 05:53 PM
cheetoh's Avatar
autozone sells entry level obd2 scanners for 50 bux, great for reading codes and removing cells.
Old Mar 23, 2010 | 06:13 PM
bleong3292's Avatar
just bought one online. thanks for the help, and i now have that link of the codes in my favorites.
Thanks guys!
Old Mar 23, 2010 | 06:55 PM
Kronn 98SH's Avatar
Thanks guys!
Get your money back. Absolutely worthless purchase.
Don't suggest stupid **** like this.
Old Mar 23, 2010 | 08:45 PM
bleong3292's Avatar
i was suggested to get one by a guy i know who sells bmw parts and races bmw's for a living. He said this will do the trick. So, i dont know why your all pissy, the tool should help with future engine problems.
(he also has an acura before you blow your head off)
Old Mar 23, 2010 | 08:59 PM
Kronn 98SH's Avatar
Let me see if I can explain it in a way that you will finally understand.
You can pull any code yourself for free, simply use my thread.
For the exact OBDII codes, you can go to ANY AutoZone and have the codes pulled for free.
Send me your $50, since you like wasting money.
Old Mar 24, 2010 | 12:56 PM
bleong3292's Avatar
ok, kronn... like i have said it earlier. the guy that was on the phone didnt know jack. he said they only had the reader for sale for $144....
I already had the code pulled from the jumper trick, but i still had to clear the light.
so i used my friend's reader, and cleared it. No more problem, so you should stop trolling and leave this thread to die.
Old Mar 24, 2010 | 01:45 PM
tofast4uh22's Avatar
im suprised this wasnt said yet. if you unplug the iat sensor yes the check engine light will come on, but if you plug it back in all you have to do is cycle the ignition and the check engine light will go off. this is not a code that has to be cleared. so if your cel is still on that means there is still a issue with the iat.
pricey2010
May 5, 2010 11:33 AM
91(si)hatchey
Mar 12, 2007 11:03 AM
sik26
Mar 19, 2005 08:02 PM
sik26
Mar 19, 2005 07:18 PM
turbogsr13z
Apr 8, 2002 11:58 AM
