answers to trouble codes
ok this is what ive got , 88 crx hf with lsvtec chiped ecu , monotech dizzy jumper, new dizzy , new intake , im throwing 4 codes and cant find the issue, any help will be greatly apprecated!
so now she is in limp mode and wont go over 3500 rpms
Code 4 Crank position sensor, at first it wouldnt start so i reversed these two wires and she cranked and ran
Code 6 Engine coolant temperature, i assumed this was the two wires at the back of the block that i need to extend to the fan switch
Code 10 Intake air temperature sensor, replaced this sensor and she still has the code?
Code 15 Ignition output signal, it has a brand new dizzy and new monotech jumper , ive checked to see if the jumper was pined right and it was.
6 isn't the fan switch.
Fan switch won't throw a code.
6 is for an actual temperature sensor.
10 sounds like you have wiring issues.
Make sure you have the connector on the right sensor - it fits on a couple different sensors that are in the same area. Trace the wires back to the ECU to make sure they are going to the right pins.
4 and 15 really sound like you have wiring problems.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/si-hf-harness-interchangable-crx-2734466/
scroll down to the hf to si harness
https://honda-tech.com/forums/showthread.php?t=2734466
USDM 4G VTEC
11
Jul 15, 2003 11:05 AM
