Rough Ride...
Old Mar 23, 2010 | 07:54 AM
ToTriggerHappy's Avatar
Default Rough Ride...
ok so i did a mini-me swap about 3 weeks ago and ever since then my car has been running wayy to rich. when i leave first gear it will jump like it wants to stall out and also if i am trying to drive a constant speed while following somebody it will jerk. There is no driving at a constant speed for me, its either speed up or slow down. also i have noticed when i open the oil cap it smells the gas bad. I just need to fix it ASAP! Low gas mileage sucks!!! any help would be appreciated!
Old Mar 23, 2010 | 08:00 AM
4g4dcruisin's Avatar
Default Re: Rough Ride...
Check the head gasket.
Do you see any smoke while your driving?
Replace the fuel injectors, fuel pressure regulator, and make sure you installed all of your vac lines and IACV, MAP, and PCV are all installed correctly.
Old Mar 24, 2010 | 10:47 AM
everything is new. and yes everything is hooked up correctally
Old Mar 24, 2010 | 10:50 AM
98civdx's Avatar
Master Detailer
what kind of ecu do you have?
Old Mar 24, 2010 | 11:03 AM
redrocket_ej1's Avatar
You sure your timing is set correctly?
Old Mar 24, 2010 | 11:41 AM
93egSLEEPER's Avatar
Any CELs? what ecu are you using?
out on a limb-could need a new basemap tune.
Old Mar 30, 2010 | 04:56 AM
i have the stock ecu for the LX. but im going with the p28 in a few weeks
Old Mar 30, 2010 | 04:57 AM
and yes timing is right on the moneyy
girl_driven
May 2, 2016 10:22 AM
B20civic28
Oct 21, 2014 05:47 AM
TurboCivicR93
Oct 17, 2011 06:05 PM
barry11j
Dec 8, 2004 05:38 AM
jeffb16
Oct 15, 2004 09:00 AM
