Exhaust Fumes entering cabin 92-95 civic
My civic hatch d15z1 started to have exhaust fumes entering the cabin under load, high rpms and climbing up hills.
Cruising speed - no fumes.
Took car to muffler shop and hr checked exhaust at idle... No leak.
Im starting to get headaches while driving.
Any help would be appreciated
there is a rubber boot under the shifter boot, make sure its still in place and sealed, just remove the center console and you will see what I am talking about
gl
gl
I had this happen to me for a while. The bolts on the header to cat could be loose. Check where all pipes meet under your car, make sure the bolts are on tight. Check the axleback as well.
Update:
slipped a piece of paper between the liftgate door and closed it- tight in some areas (hard to pull out) and loose in other areas (slided out easily)
found the areas that are not sealed!
Slipped the paper again between the backglass and the liftgate- again found the areas that were not sealed...
New weatherstrip is $100!
Ill try to adjust the glass and liftgate..
doompa
Honda Civic (2001 - 2005)
Mar 21, 2011 06:03 AM
DUKE LADUKE
12
Jan 19, 2011 11:22 AM
