Exhaust Smell coming through hatch ?!? HELP
Having my exhaust creep through the hatch when I am boosting or at a idle . Any idea on how I can seal it up more. I played with the bracket latch that holds the window down and still nothing . Really starting to **** me off
Re: Exhaust Smell coming through hatch ?!? HELP
fix the exhaust leak, you shouldnt smell your exhaust when your driving. Maybe a small pin hole? or the muffler located to far behind the bumper?
it wouldn't be coming through the cab if u didn't have an exhaust leak. fix that and u should be good to go. this is why i stopped running open down pipe because it was loud and i could smell exhaust
Exhaust leak ckeck for holes or cracks and if its got flanges where it bolts togeather make sure they are tight and the gasketds are good
There is a sealant that comes in a spray can from Lowes/Home Depot, that we use often. You can spray it on your welds and connections and it should help; i would also get some high temp paint and spray the cat cover, piping and area's from the header to rear axle; the spray should cover up any pin hole leaks. if you continue to have the smell, then your going to have to remove and replace gaskets, and other parts until its fixed.
There is no exhaust leaks though. When I go through the car wash ,water leaks through the hatch glass section . Even though its already tight down .
it might b ur rear lights. i had the same problem and i took apart the hole rear end i found one of the clips that fastens the rear light to the car was broken
Could be a couple of things. Start with tightening up your tails, make sure your spoiler is tight and if none of that works you may want to look into replacing the hatch and window seal. Chances are (IMO) the the seal around your rear window. The window it self will have a good bit of flex to it and can lift off the seal.
acidburn2k2
01-07-2006 01:03 PM
doggunracing
02-27-2005 12:41 PM
