ITR idle problem
Old Mar 22, 2010 | 07:40 PM
duckiexd's Avatar
Default ITR idle problem
hey i got a teggy wit 98 jdm specs itr swap and it has problem startin up in the morning. it wont stay on unless i hold down the gas to warm up my engine. i think i have no idle control. what can i do to fix it? i searched but i cudnt find anythin.
Old Mar 23, 2010 | 07:29 AM
Tyrant_007's Avatar
Default Re: ITR idle problem
Any check engine lights? After it is warmed up does it run perfect? Have you checked the fuel pressure? You can adjust the idle by turning the screw on the TB. Need more info...
Old Mar 23, 2010 | 07:39 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
when you say hold it down do you mean to the floor or just enough to keep it from stalling??
Old Mar 23, 2010 | 09:04 AM
duckiexd's Avatar
keep it from stalling. but im in neutral tho not in gear.
Old Mar 23, 2010 | 09:07 AM
duckiexd's Avatar
and i got a check engine light on but i cant read the ecu cuz its a jdm ecu so idk wats wrong. and the engine run fine after its warm up. i havent check the fuel pressure yet. kinda.. dont noe how to do tat.. lol
Old Mar 23, 2010 | 10:08 PM
Tyrant_007's Avatar
You should still be able to figure out the CEL code by using a scantool. Just take it to a store like autozone/shucks/checkers/napa, and they can usually scan it for you.
Old Mar 24, 2010 | 08:13 AM
duckiexd's Avatar
ohh okayy thanks alot and my mech scanned it a while ago and it cudnt read for some reason do u think is cuz my ecu is jdm??
Old Mar 24, 2010 | 01:02 PM
Tyrant_007's Avatar
I don't see why it wouldn't be readable, unless some funky wiring has been done. Anyone able to confirm that an OBD2 JDM ecu can be read with a scantool?
Old Mar 24, 2010 | 01:18 PM
Slain's Avatar
you could do the paper clip trick to read codes albeit its a little longer process.
Old Mar 24, 2010 | 05:29 PM
duckiexd's Avatar
ohh how do u do the paper clip thingy?
and thanks imma try to use the scantool i tried to go to autozone today and they dont check it anymore they said i got to buy the scantool its like 60 buck im debating if its worth it to buy it or not. and thanks for the help guys
Old Mar 24, 2010 | 05:32 PM
PYITR678's Avatar
Its not worth it, you just jump the ECU with a paperclip. Thats basically free.
Old Mar 24, 2010 | 05:41 PM
builthatch's Avatar
MiG-21 superfan
here-
Originally Posted by builthatch
eggzackly.
paperclip to jump the two holes in the service connector in the passenger side kick panel. it's a two terminal green plug with a blue rubber cover, or a blue plug with green cover - i forget.
long blink = 10, short blink = 1
long blink long blink short blink short blink short blink...space....long blink short blink short blink...space...
that would be code 23 and code 12.
random codes used just for example.
Old Mar 24, 2010 | 05:54 PM
PYITR678's Avatar
BTW, are you using Crome, UberData, or some other freeware tuning software?
Old Mar 24, 2010 | 08:21 PM
duckiexd's Avatar
okayy thanks for the help guys
and i dont think i am? ahah the guy tat sold the car to me didnt say anythin about any chipped ecu lol
and i just borrowed my mechs scantool and i tried to read the ecu its said connector error.
Old Mar 24, 2010 | 08:30 PM
builthatch's Avatar
MiG-21 superfan
yeah, scanner no dice with jdm ecu ; )
Old Mar 24, 2010 | 08:49 PM
duckiexd's Avatar
wait wat do u mean scanner no dice wit jdm ecu? lol sorryy im kinda new to this
Old Mar 24, 2010 | 08:56 PM
builthatch's Avatar
MiG-21 superfan
oh, i'm just saying that a scanner will definitely not work with a JDM ecu. you need to do the code pull process that i detailed ; )
Old Mar 24, 2010 | 09:23 PM
duckiexd's Avatar
haha damn... yeaa tats wat i thought.. gayy well ill probably try it tmr and see wat code i get thanks for the help guys. ohh and if i want to chip my ecu wat brand shud i get? i heard s300 are the most recommended
Old Mar 24, 2010 | 10:54 PM
PYITR678's Avatar
Unless you plan on boosting or running nitrous and/or need data logging, get an S100
Old Mar 25, 2010 | 07:01 AM
duckiexd's Avatar
ohh so if im just gettin i/h/e i shud just get the s100? and shud i chip the p73 ecufor my car? or cud i use a different ecu
Old Mar 25, 2010 | 07:07 AM
Todd00's Avatar
I said I don't want a title!
You don't even have a Type R, do you? My guess is you have a normal Integra with a swapped JDM ITR motor.
If that's the case, then you need to post in a forum that caters to JDM swaps, such as the hybrid forum.
lsvteg11
Sep 17, 2010 11:50 AM
crx-newbie
Sep 7, 2009 09:47 AM
winterbear09
May 4, 2004 10:11 AM
yoshio006
Dec 17, 2002 06:18 PM
PiYoImuT
Sep 7, 2001 09:08 AM
