How to wire a dvc sub in with a 2 channel amp?
Old Mar 22, 2010 | 07:08 PM
CDdubz5's Avatar
Default How to wire a dvc sub in with a 2 channel amp?
What's up guys? I have a really quick and simple question, my problem is my friends don't speak 'audio' so here goes:
I am picking up a 12" mtx 5500 thunder series sub and I will be hooking it up to my sony xplod 2 channel amp. Now, how should I hook the sub up? Should I run wires from each channel to the separate voice coils or should I run the voice coil wires in series and use the amp as a mono block?
any help is appreciated! and if anyone would like a refurbished 15" JL w0 v1 then please let me know
Old Mar 23, 2010 | 08:56 AM
El Civ's Avatar
Default Re: How to wire a dvc sub in with a 2 channel amp?
it depends on if the VCs are 2 ohm or 4 ohm.
Old Mar 23, 2010 | 10:36 AM
CDdubz5's Avatar
they are 4 ohm voice coils...sorry i didnt state that before
Old Mar 23, 2010 | 12:35 PM
El Civ's Avatar
Wire them in series and bridge the amp, thus making the amp see an 8 ohm load.
Old Mar 23, 2010 | 02:14 PM
mhart's Avatar
DO NOT wire each coil to it's own channel, wire it 8 ohms and bridge the amp, if you do each coil off of a channel depending on the music it could have the coils playing against each other. What size is the amp? because w0 have low power handling so at 8 ohms you should be ok.
Old Mar 23, 2010 | 03:41 PM
El Civ's Avatar
^ oops, yeah you're right.
Old Mar 23, 2010 | 05:29 PM
CDdubz5's Avatar
ok cool thanx guys. it is a 1200 watt amp. so i know i'll have plenty of power for the sub. since you mention it matt, it makes sense that i shouldnt wire them to separate channels
Old Mar 23, 2010 | 06:00 PM
El Civ's Avatar
I hate to burst your bubble, but it isn't a 1200w amp.....that's the MAX power rating, and that rating means virtually nothing.
It's the RMS rating that you should always look at.
Old Mar 23, 2010 | 06:22 PM
CDdubz5's Avatar
yeah i know dude. its 1200 watts max x2 at 2 ohms and 600w rms x 2 at 2 ohms
Feli
Audio / Security / Video
10
Dec 13, 2010 07:57 PM
vadimqwe
10
Mar 10, 2010 04:24 PM
I Want An Si
10
Apr 9, 2008 02:53 PM
ReV LiMiT
Mar 12, 2006 02:41 PM
dpmac10
Sep 27, 2003 02:56 AM
