map sensor wiring q
Old Mar 22, 2010 | 04:21 PM
gnar kill's Avatar
Default map sensor wiring q
ok so I have a 95 civic dx that was originally an auto. I bought it as a non runner with a manual ls vtec in it. The wire for the map sensor is not in the engine harness or on the firewall......weird....Can I just run one wire to the ecu for the signal wire and get the 5 v positive and the ground off of the same 5v positive and ground that the tps use in the engine harness. Thanks
-Casey
Old Mar 23, 2010 | 03:39 AM
gnar kill's Avatar
Default Re: map sensor wiring q
anyone see a problem with doing this
Old Mar 24, 2010 | 03:09 PM
gnar kill's Avatar
still need an answer.....can I use the same power and ground wire as the tps for the MAP. Thanks
-Casey
Old Mar 24, 2010 | 03:22 PM
nsxter's Avatar
yes you can
bubxba
Apr 13, 2008 05:54 PM
autosport
Jun 15, 2005 02:11 PM
SOFLSOL
Sep 2, 2003 05:41 PM
This One
Feb 2, 2003 04:20 AM
