Honda S2000 Honda S2000
starving for fuel?
Old Mar 22, 2010 | 04:06 PM
backstrap1's Avatar
Icon6 starving for fuel?
2002 S started stalling when making a sharp turn "U TURN" kinda heavy on the gas. Anyone come across this? Almost like its not getting fuel. Had half tank when it started doing this, so I filled it up and its still doing it. Other then in a sharp turn there are no stall problems.
My first thought is a fuel filter...only thing is I cant seem to find info on where they(it)are located.
ANY help or ideas appreciated.
Old Mar 22, 2010 | 04:48 PM
JDMF22B's Avatar
Default Re: starving for fuel?
What's your oil level look like? How much oil did you put in? if you put in more than 5.5 this might be the cause
Old Mar 22, 2010 | 05:25 PM
bigmacnfries's Avatar
How does too much oil starve the engine of gas?
Old Mar 22, 2010 | 06:32 PM
backstrap1's Avatar
Oil is checked every time I fill up. (once a week or so). Always on the full mark.
Positive its a fuel problem.....Trien to figure out if the filter on the fuel pump is the only one, in which case I will just have the fuel pump changed while the works being done. If there is another I could change first ....even better.
If it was the fuel pump wouldnt it stall out any time I got on it?
Tegraracer90
Mar 25, 2007 07:56 AM
IAteg
Nov 11, 2005 12:34 PM
DaveF
Jul 30, 2004 04:28 PM
DaveF
Jul 30, 2004 07:10 AM
