looking for a budget build that will pass CA smog
Old Mar 22, 2010 | 01:19 PM
pandaevo's Avatar
Default looking for a budget build that will pass CA smog
OK so I am at a point where I have done everything I could think of to fix a problem of my B18C1 burning oil. I put new valve stem seals, new PCV, did a compression test and results were 190/191/189/190, did a leakdown test, running a chipped P28 ECU. I do not have any coolant in my oil, plugs are dry and its running a little rich. From 3500 RPM and up I get a noticable bluish smoke form the exhaust. So...I guess its time for new pistons/rings. The question is which ones to go with. I live in Cali and we have crappy 91 oct gas, My hatch is Bar'd and I this is my daily driven car. With that being said I want to keep it able to pass smog and reliable. I plan at some point when it stops burning oil to do Skunk2 springs/retainers w/ Pro 1 cams. I already have Skunk Pro IM. Do I stick with GSR pistons, or can I get away with running ITR pistons/rings and still pass smog??? I just would hate to put stock pistons and then to find out that if I only spent another $100 I could have made more power. Any advice is greatly appreciated
Old Mar 23, 2010 | 09:46 AM
m_shake's Avatar
Default Re: looking for a budget build that will pass CA smog
I passed smog with flying colors on my build. its a b18c1 w/.25 os usdm itr pistons, endyn ported head, skunk2 im, itr cams w/ supertech valvetrain. It was enough to put down 177whp on blacktrax's dynapack dyno
Old Mar 23, 2010 | 10:14 AM
pandaevo's Avatar
thanks a lot!!! I am putting in my order for some RS machine P73 pistons today
Old Mar 23, 2010 | 10:37 AM
m_shake's Avatar
you getting jdm or usdm style? cause the jdms will have more compression....also when i smogged my car it was with a brand new OEM cat(I had a random tech one but that went south very quick, total waste of money).
slimjimming6688
Dec 15, 2008 08:23 PM
nokturnal_munkeeboy
18
Jul 2, 2007 10:38 PM
sd_pinoy858
Mar 7, 2004 07:29 PM
Luserkid
Aug 3, 2003 03:30 PM
One8Hatch
Nov 25, 2001 09:12 AM
