Walbro 255 Fuel pump On stock B20b ok??
Old Mar 22, 2010 | 11:50 AM
93grayeg's Avatar
Icon6 Walbro 255 Fuel pump On stock B20b ok??
Hey guys I had a boosted b20b in my hatch im looking to just stick a stock b20 back in it and leave it all motor, am I going to be okay leaving the walbro pump in from my turbo set-up? Thanks guys
Old Mar 22, 2010 | 08:39 PM
93grayeg's Avatar
Default Re: Walbro 255 Fuel pump On stock B20b ok??
over 20 veiws and NO ONE knows this??
Old Mar 22, 2010 | 09:10 PM
092eg6's Avatar
i think u might be running rich without a tune.
Old Mar 23, 2010 | 08:58 AM
93grayeg's Avatar
Yeah thats what I figured , are the stock injectors going to be okay with the 255 pump?
Old Mar 23, 2010 | 09:25 AM
em_at_kfi's Avatar
The answer to the OP's question is 'Yes'
Lets say i have a 50 lb/hr injector at 45 psi and WOT / max. load values in the fuel table are 80% duty.
50 x .8 = 40 lb/hr
So, as long as I don't change the fuel pressure or size of the injector - what difference does it make if my pump is putting out 400 lb/hr or 4000 lb/hr? The pump has nothing to do with duty cycle/tune.
Old Mar 23, 2010 | 09:37 AM
vtec8200's Avatar
wouldn't the fuel pressure increase in proportion of how many lph the pump puts out?
Old Mar 23, 2010 | 10:17 AM
em_at_kfi's Avatar
no, the pressure relief valve is what determines fuel pressure. you're just bypassing more.
doesn't matter if you have a weldon or a walbro, if you have an adjustable pressure relief valve, you can set fuel pressure to whatever you want.
now, if you put a monster weldon pump on it (like a 2345) with a stock pressure relief valve, the stock pr valve won't be able to bypass everything the pump puts out, and in that case you'd see a steady increase in fuel pressure the longer the car ran. But this will not be the case with a 255 + stock pr. you're fine.
Old Mar 23, 2010 | 10:29 AM
vtec8200's Avatar
Got it, thanks for the info!
Old Mar 23, 2010 | 10:38 AM
em_at_kfi's Avatar
people get tripped up on this quite often.
just keep pressure and volume separate.
You can have a system flow 1 lb/hr of fuel at 10,000 psi
or
You could flow 10,000 lb/hr at 1 psi
Old Mar 23, 2010 | 11:17 AM
93grayeg's Avatar
okay so im going to be fine with the pump , As long as i keep the dsm 450s??
Old Mar 23, 2010 | 12:33 PM
noboostedEGo's Avatar
no. if you're gonna run it stock (with walbro), with a stock ecu, put in stock injectors.
if you are running on a map tuned for 450s, then use 450s.
CFDOHCVTECEG
Feb 2, 2007 03:32 PM
Tinker219
Honda S2000
13
Jan 8, 2005 08:37 PM
Todapwr
May 12, 2004 07:51 PM
M.K.C.
Nov 17, 2003 10:43 AM
ridnmyhonda
Apr 1, 2003 01:00 AM
