battery is good but car has no power help!
Old Mar 22, 2010 | 11:18 AM
CTR LOVER LU's Avatar
Icon2 battery is good but car has no power help!
hey i just put a vtec head on my 96 ek the car started once. now all it does is beep wen u put the key in but wen u turn the switch theres no power wat could this be????
Old Mar 22, 2010 | 11:25 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: battery is good but car has no power help!
power wires. are they tight? starter any good?
is there a click. or just plain dead? any lights come on?
more info
Old Mar 22, 2010 | 11:36 AM
the only way things work is if another car is jumpin it other then that dead
Old Mar 22, 2010 | 11:41 AM
I'm not Rick!
Originally Posted by rick_rabies
starter any good?
more infooooooooooooo
Old Mar 22, 2010 | 11:57 AM
starters good the car will start only with jump cables all fuses are good the battery is in the trunk but ive had it like that for months with no prob. the main relay works. my problem is that without a jump from another car the car is completly dead the only thing that happens is wen u put the key in it beeps but wen u turn it everything is completely dead.
Old Mar 22, 2010 | 11:59 AM
apexi_rsx's Avatar
sounds like a poor ground.
Old Mar 22, 2010 | 12:06 PM
thats what i thought but any where i put the ground it does the same thing. plus wen o put the cables on the battery it doesnt spark.
Old Mar 22, 2010 | 12:45 PM
97twodoor's Avatar
How do you know the battery is good? You said that when you get a boost everything works fine, which points to a bad battery.
Old Mar 22, 2010 | 12:57 PM
i tried the battery in the car at first thats wat u thought so i excanged it and it did the samething so i tryed my eg battery and nothing so i tried 3.
Old Mar 22, 2010 | 01:09 PM
trickster kid's Avatar
battery cables may be bad
Old Mar 22, 2010 | 04:03 PM
canadaek's Avatar
is the motor grounded to the body???
Old Mar 22, 2010 | 07:22 PM
1992cxcivicEG's Avatar
sounds like loose terminals to me homie
Old Mar 22, 2010 | 09:55 PM
BlinkerFluid992's Avatar
terminals or the ground isnt "grounded"
Old Mar 23, 2010 | 08:32 PM
it was the fuse box under the hood i tookit apert n it was all burnt up got a new one everything works fine now thanks for everyones help
Old Mar 23, 2010 | 08:36 PM
heres the hatch by the way
squirrly
May 11, 2008 07:40 PM
pendejon
Mar 10, 2006 03:12 PM
typerev
Dec 19, 2003 11:47 AM
EF Two
Oct 3, 2003 08:39 PM
