d15b swap ecu needed for start?
i did a d15b7 to d15b swap, Let me sum this up for everyone, I have spark, timing is correct,Fuel is priming,Compression is 160+ across, All grounds are correct, but it is not starting, it turns over but doesnt start, but i havent boughten the p28 ecu yet which means i have not wired the vtec and the oil pressure switch yet, do i need those for the car to start?
you dont need vtec wired but im pretty sure you do need the correct ecu for the engine. My d15b isnt running off of a p28 though. i believe is a p06. p28 are for z6 and y8 i believe but dont quote me on that.
the d15b will run on a p06 jsut with out vtec i ran like that for a while p28 will work fine and have vtec cheepst bet chip ur p06 adn convert it to vtec http://www.moates.net/
my D15B is doing the same thing its pissing me off lol....i have every thing spark fuel gruond's....and i have a p28 ecu on its way but do i need a vtec dizzy or can i just use my 0bd2a dizzy and run wires for my vtec... or what about the jumper they have from the obd1 to obd2 would i need to do any thing els? if i buy the jumper
showbowt
Mar 19, 2008 03:06 PM
NatedoggAZ
Jul 31, 2003 05:01 AM
