clutch issues
Old Mar 21, 2010 | 02:41 PM
duyfash0's Avatar
Default clutch issues
so my car didnt go into gear when car was on. i put in more fluid and pumped my pedal about 10 times and it works again. i looked under the pedal and theres some fluid leaking. so does that mean my clutch is fine and i just need to replace the master cylinder? thanks for any input on the problem.
Old Mar 21, 2010 | 03:08 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: clutch issues
Most likely. Be certain the fitting isn't leaking.
Old Mar 21, 2010 | 04:08 PM
-__-'s Avatar
look at the fittings on the lines to see if they are leaking first. then if it's not that, then u may need to replace the seals (rebuild) your master cylinder.
Civic Racer X 7
11
Aug 27, 2014 05:53 PM
dgerej2
Oct 1, 2009 07:16 AM
iNfAmOuS_E46
Mar 18, 2009 02:02 AM
zc89hatch
Apr 1, 2008 05:37 AM
GraphiteMW
Mar 25, 2007 09:26 AM
