Brake lights blowing fuse
My '91 Si keeps blowing the fuse. I thought it was my stereo causing this, so I removed the amp/sub. The only major electrical component is my Compustar starter. It still lights up if the parking lights are on.
Any ideas where to start? Something simple like a bad bulb, or more complicated?
Thanks.
Thanks.
i remember in my integra i would blow my brake lights fuse then i found that my horn wires were grounding and that was popin my fuse i cant remember if ef share the horn/brake fuse
I'll have to re-check the horn wires again tomorrow since it was getting pretty dark.
I removed a connector beside the fuse box and it has some greasy residue on top of the wire harness and the terminals on the bottom. Is this normal?
Rhythm Racer
11
Jun 27, 2003 10:46 AM
