ecu question
^^woah lol.
anyway u should use the P30 if you are not using the STOCK GSR Intake Manifold.
P72 fuel map would be crappy for that because its programmed for the GSR's intake manifold butterflies.
but on the B16 block regardless, use the P30 and unplug the Butterflies if you have that manifold.
nsxter: knocking other peoples' builds is unnecessary. The GSR head is actually a better design than the b16 and the flow is almost the same the the point you're splitting hairs even bringing it up.
j351w: any VTEC ECU will work. A P28 would probably be the cheapest. You really should tune any hybrid combination like that. The increased compression and more aggressive cams won't like a stock fuel map, or at least you'd probably make more power with a custom tune.
You shouldn't even think about driving it until you get a chipped ECU and either take it to a tuner or tune it correctly yourself.
"Any VTEC ECU will work" is a ridiculous statement. You will not know what your AFRs are. You could be running 20:1 AFRs at wot... It would be crazy to drive like that.
And there is no guarantee that a generic basemap will work well with your setup. Unless it was made by a VERY experienced tuner, the values are usually way off.
Now anyone who has a chip burner calls themselves a tuner....
Bottom line: car needs to be tuned with at least a wideband and det can
black-ek9
12
Apr 6, 2004 01:29 PM
