Alignment question, do I need one?
Old Mar 20, 2010 | 06:04 PM
caliskier's Avatar
Default Alignment question, do I need one?
I had the alignment checked on my 1995 vtec prelude today and decided not to pay for one. I checked the specs and I am in spec for almost all of the measurements
The tire store said I needed to adjust my front left toe, it was 1/16th which is 0.0625in which is actually in spec, the speck is 0in +/- 0.08in.
They also said I needed to adjust my rear toe as it was 1/8th which is 0.125, this is a little out of speck, speck is same as above.
They also said the steer ahead was 0.08 degrees, and needed adjusted, I could not find the speck for this.
Lastly they said my caster on my right front was really bad, 0.3 degrees. The spec for this is 2 degrees 40 minutes +/- 1 degree. This means that I am way off, about 2 degrees.
The first one I am not concerned about, the second two I am asking if I should be concerned about them?
The caster, doesn’t this just mean my wheel is pushed back? If it still drives straight, what problems will this cause me? I was hit 4 years ago on that wheel; I have not noticed ware on the tires, and don’t think I am replacing them too often.
Old Mar 20, 2010 | 07:36 PM
Kronn 98SH's Avatar
Default Re: Alignment question, do I need one?
If the car drives straight and tires don't wear unevenly or prematurely, then leave it alone.
Old Mar 21, 2010 | 07:16 PM
X-bb4lude-X's Avatar
is it lowered any?
Old Mar 21, 2010 | 08:39 PM
jlude90's Avatar
The caster will make the car wander a bit, but its kinda whatever.
I'm not going to say you couldn't use it. But you'll probably be fine without an alignment.
89ED
Suspension & Brakes
12
Jul 20, 2013 07:05 PM
asmallsol
Apr 13, 2004 09:32 AM
Ludeboi
Sep 26, 2003 05:41 PM
Flux
Jun 21, 2003 07:24 PM
Chris N
Oct 17, 2002 12:13 PM
