Simple prob I know you guys can HELP (NO FUEL Pressure)
Man here is the deal. The car was running good, a little lean but running none the less. When I shut it down the car wouldn't even start up again. When I turn the key there is no fuel running, can't hear, smell, and the fuel pressure gauge doesn't move. I changed the fuel pump and still no fuel. I know itz sumthing dumb so could someone please point me in the right direction. Like should I test something or check something? Oh yea itz a H22A in a 94 EG. Also whats a good ecu to run once I DO get the car running?
The swap was done last week. I drove the car to a show and came back. It ran fine for a day then like I said I just turned it off and when I went to turn it on again there was no fuel. I checked all the fuses and there were no blown ones. How would I check to see if power is gettin to the Fuel Pump? Thanks
sol2nr
11
Jun 23, 2004 06:36 PM
Boostless97Lude
Dec 26, 2002 11:33 AM
