Is this excessive blowby ? Video included
Old Mar 19, 2010 | 08:34 PM
accord99power's Avatar
Default Is this excessive blowby ? Video included
Setup is in the signature. Could you guys listen and tell me if i need to be worried. Right now there is 215 compression across board, no exhaust blue/grey exhaust smoke, solid vacuum.
*also could you listen for engine knock please, im not very familar the sound difference between knock and loud tapping valves. Valves were adjusted by me about 6k miles ago.
heres the link:
http://www.facebook.com/video/video.php?v=390778556304
Old Mar 19, 2010 | 09:20 PM
slomofo's Avatar
GDD Member
Default Re: Is this excessive blowby ? Video included
Good God man, learn how to adjust your valves.
Also, ummm, everyone's oil will shoot out if you take the cap off. If you have excessive blowby, your dipstick will pop out in high RPMs.
Old Mar 20, 2010 | 04:42 AM
so valves just need to be readjusted? haha learning man went by the haynes manual but it didnt seem accurate.
GhostAccord's Avatar
That sounds & looks normal to me. The tick is definitely top end. Do you have an aftermarket cam? I'm only asking because I have heard that some cam grinds cause the valve train to make a bit more noise than a stock cam would.
Old Mar 20, 2010 | 04:44 AM
no sir stock cam. so readjust valves for sure?
Old Mar 20, 2010 | 04:48 AM
It wouldn't hurt.
Honestly that doesn't sound all that bad. I have heard a lot worse. Sometimes they just tick a little bit.
Old Mar 20, 2010 | 05:23 AM
thanks ghost for the info will do.
Old Jan 26, 2011 | 09:10 AM
nus_dogg's Avatar
I thought air pumping out like that is normal with the oil cap off while engine is running???
You'll have to do a leakdown test to really find out if you have cyl wall tapered or loss tension of compression rings.
accord99power
Mar 19, 2010 09:06 PM
spriddle
Dec 16, 2008 04:02 AM
sbcs15
Sep 13, 2005 07:35 PM
Soccerking3000
11
May 15, 2004 09:29 AM
94civicx
Feb 20, 2002 06:53 PM
