B20 swap into EG help!!
Old Mar 19, 2010 | 12:55 PM
ej2Tigre's Avatar
Default B20 swap into EG help!!
i know its probably been covered a million and one times but i have been hunting for days on end and cant find jack... im doing a b20 swap into my 94 coupe so far i have
motor, tranny, linkage, 0BD1 LS intake, Hasport mounts, 0BD1 ls Dizzy, new clutch n flywhee, starter.. i know i need axels but other than that what am i missing?
my real question is can i reuse my D series Transmission bolts? and mount bolts?? slave cylinder?
please dont flame me or tell me to "research" because thats AAAALLL ive been doing i actually need real HELP
Old Mar 19, 2010 | 12:56 PM
ej2Tigre's Avatar
Default Re: B20 swap into EG help!!
oh and its a b20 long block with alternator n all that good stuff
Old Mar 19, 2010 | 01:02 PM
ej2Tigre's Avatar
two views so far..
Old Mar 19, 2010 | 02:03 PM
Gunmetal_B20_Hatch's Avatar
Originally Posted by ej2Tigre
two views so far..
If you plan on reusing clutch/flywheel bolts, you will need 2 more flywheel bolts. D's have 6 and B's have 8. Almost 90% of the bolts will transfer over. You are going to need a half-shaft(and bolts) also and ECU
Old Mar 19, 2010 | 02:16 PM
ej2Tigre's Avatar
You just saved me.. no bullsht! so will i need a new flywheel too? im assuming i will
Old Mar 19, 2010 | 02:31 PM
dickie691986's Avatar
yep
Old Mar 19, 2010 | 02:38 PM
jayWknight's Avatar
I know this engine swap inside out.
1. b20b/b4/z2 engine longblock
2. OBD1 ls intake manifold with fuel rail and fuel pressure regulator. Reuse your fuel injectors.
3. 94-01 integra ls throttle cable (20 bucks from the dealership)
4. 94-95 integra ls distributor
5. 94-95 integra ls throttle body with FITV
6. 94-95 integra IACV
7. Reuse the IAT sensor from your d-series
8. Any b-series header
9. Reuse your engine harness from your d-series engine. A few plugs will need to be extended.
10. hydro b-series transmission LS/GSR/SI/ITR (transmission to engine bolts are the same as d-series)
11. clutch and flywheel from any b-series 94-01 integra/92-97 del dohc vtec/99-00 civic si
12. flywheels can be reuse from your d-series or pick up a set of arp flywheel bolts for 50 bucks
13. half-shaft from any b-series 94-01 integra/92-97 del dohc vtec/99-00 civic si
14. B-series axles any b-series 94-01 integra/92-97 del dohc vtec/99-00 civic si
15. T-bracket from any b-series 94-01 integra/92-97 del dohc vtec/99-00 civic si
16. b-series transmission front mount any b-series 94-01 integra/92-97 del dohc vtec/99-00 civic si
17. If you have A/C, you will need a 97-00 honda crv ac bracket with tensor pulley (require for a working A/C)
18. A b-series power steering pump from a 94-99 integra, if you have power steering and want to maintain it.
18. You can send me your ecu and I can chipped with a LS map, therefore cutting out the cost of buying a 94-95 integra ls ecu.
Old Mar 19, 2010 | 02:42 PM
ej2Tigre's Avatar
****... hoped i didnt. i might end up being stuck with a LS tranny.. with a b20 will it really be that bad? i drive pretty far everyday so..
Old Mar 19, 2010 | 02:43 PM
ej2Tigre's Avatar
DAMN JAY!! your the **** i must say lol to bad we cant rep
Old Mar 19, 2010 | 02:47 PM
ej2Tigre's Avatar
how much did this all run you btw? and how long did it take
Old Mar 19, 2010 | 06:47 PM
jayWknight's Avatar
325 for the engine
60 bucks for a full set of gaskets for the engine
50 bucks for a ls transmission with a broken ISB
20 bucks for a ls intake manifold
20 bucks for a ls throttle body
120 for axles
90 bucks for a bunch of misc parts
About 700 bucks total and I saved by not having to buy the ecu. I chipped my old ecu and tuned it.
Old Mar 19, 2010 | 06:55 PM
98y8's Avatar
sorry to thread jack but just a small question, jay do you know what kind of headers other than itr headers i can use for my b20z in a ek?
Old Mar 19, 2010 | 06:59 PM
jayWknight's Avatar
Any b-series header you want. All b-series header's have the same bolt pattern.
Old Mar 19, 2010 | 07:01 PM
lobudgetr's Avatar
You should be able to use any b-series header, just depends on what you want it to do.
Old Mar 19, 2010 | 07:11 PM
ej2Tigre's Avatar
damn that was ah cheap swap.. is it still goin to be faster than my z6 since im usin the ls tranny? people keep sayin its goin to be slow
Old Mar 20, 2010 | 12:58 AM
jayWknight's Avatar
Night and day differences with the amount of torque a b20 has at 2-4k rpm range.
Old Mar 20, 2010 | 05:02 AM
BryanM.'s Avatar
Resident Gearhead
Does the LS map run the B20 perfectly? What I mean is, it's a map designed to run a 1.8L, will it work just the same as the B20 map?
Just wondering, I'm not too knowlegeable about this stuff.
Old Mar 20, 2010 | 06:17 AM
ej2Tigre's Avatar
^ personally im running my chipped ecu
Old Mar 20, 2010 | 07:34 AM
jayWknight's Avatar
Most factory ecu's run rich to meet emission requirements. This extra fuel is prefect for the b20 with its extra .2L. Although a dyno tune would be better. I was lean due to my elevation.
Ej2tiger make sure your chipped ecu is loaded with crap load of fuel with all the sensors disable.
Old Mar 20, 2010 | 02:08 PM
ej2Tigre's Avatar
so would a street tune be good or i need to dyno it?
Old Mar 20, 2010 | 08:49 PM
BoXiNWrX's Avatar
dont' wanna thread jack but it's related, i'm doing b20b into my eg sedan, i have ordered alot of **** since it was just a shell i bought with NOTHING left in the engine bay....and i'm gonna be doing B20V once i get it running i'm gonna do the head swap....my question is engine harness? and do i need all this stuff like the obd1 intake mani and stuff? since my motor is a obd2? and can i just get a gsr engine harness for now, and can i run a p72?
Old Mar 20, 2010 | 08:54 PM
ej2Tigre's Avatar
well the mani is so you can close your hood i think
Old Mar 20, 2010 | 08:58 PM
BoXiNWrX's Avatar
ahhh...gotcha, yea i haven't gotten the motor yet saving that for last so i can save myself the problems if anything goes wrong (30 day) start up fee blah blah
Old Mar 21, 2010 | 10:44 AM
CleanazzEJ1's Avatar
I didnt think anyone mentioned that he needs b series shift linkage as well
Old Mar 21, 2010 | 10:57 AM
EKHatch_617's Avatar
probably cuz he sed he has one. but bump im doin same swap i still need the b series shift linkage and other minor things. extra fly wheel bolts nd such
