evaluate my current build d16-t please
d16y8 block, z6 forged srp pistons, h beam rods
-a6 head gasket (i believe this makes 9.03:1 cr)
-z6 head- crower springs and retainers
-shimmed oil pump
-y8 crank
t3t4, hks bov, tial 38mm gate, ram horn
450 cc dsm injectors/ 255 walbro pump
p28(will be chipped and tuned)
this is my first turbo build and im looking for some advice, or if i sound like i know what im talking about at all.
-shimmed oil pump
-y8 crank
i used a compression calculator, it allowed me to choose a6 head gasket and that brought compression down to 9.03:1. thats why i am asking.. can i use a6? And why z6 crank versus y8? Im shooting for 300+ whp
I would use the Vtec H/G, so it will have all the oil galley holes you need.
You could get a cometic gasket then you can choose the thickness, so you can have the compression you desire.
hmmm yea i havent compared head gaskets to see what the differences are yet, just knew a6 would yeild lower compression... cometics are twice the price of regular head gaskets.. maybe ill just stick with the y8...
a6 head-
http://media.photobucket.com/image/a.../RACE013-2.jpg
z6 H/G-
http://tachedout.com/shop/images/Com...ead-Gasket.gif
Lol. Hardly. The most solid advice you have yet is to toss that crank. Don't think so? Invest in larger injectors, run more boost/hp and then come back here in a while asking why you spun a rod bearing. Hey, at least at that point you'll have bigger injectors to run more power when you rebuild the second time, right?
No need to worry about dropping the compression. 9.x is fine for a street turbo motor. If your goal is in the low 300s, you should be able to pull that off with 93 octane on a ~9.5 compression motor.
The higher compression should make the turbo more responsive on the street anyway.
k5egg
Feb 25, 2011 01:56 AM
AceGates
19
Mar 20, 2010 11:00 PM
