rpm reading wrong help
Old Mar 18, 2010 | 11:11 AM
thisboyjulio's Avatar
Default rpm reading wrong help
motor at low idle about 800-900 rpm....... speedometer reading 1600-2000 this problems happens sometimes dont know whats causing this too happen. when accelerated rpm seems too be behind on reading the actual rpm it sometimes jumps up and jumps down. sometimes when i start car the rpm is reading accurate at 900 rpm.
Old Mar 18, 2010 | 11:14 AM
Dkober101's Avatar
Default Re: rpm reading wrong help
is this your OEM cluster or did you install this?
Old Mar 18, 2010 | 11:27 AM
installed the cluster 1 yr ago been working fine since then. till now.
Old Mar 18, 2010 | 01:18 PM
any sensors?
lostsonta
Sep 3, 2012 03:39 PM
949
Feb 1, 2008 08:30 PM
EG-HK
Sep 14, 2007 08:05 AM
Chuji
Mar 3, 2005 01:22 PM
AllmotorJunkie
Aug 20, 2003 05:14 PM
