Pulled out spark plug, there was some water....
Old Sep 8, 2002 | 07:55 PM
Tofurky's Avatar
Default Pulled out spark plug, there was some water....
pulled out plug #1, there was a tiny bit of water. all others were fine. let it dry, motor turns, but won't start....
any ideas?
we dropped in a jdm b18c1 into a 92 cx
Old Sep 9, 2002 | 10:16 AM
badCRX's Avatar
New User
Default Re: Pulled out spark plug, there was some water.... (Ruckus138)
If this is a brand new used motor, I wouldn't worry about it. Give the motor a couple days to smoke and burn all that old chit out. After a couple days it should be gone and act like it should.
Old Sep 9, 2002 | 12:35 PM
Tofurky's Avatar
Default Re: Pulled out spark plug, there was some water.... (badCRX)
the motor won't start either
Old Sep 9, 2002 | 01:21 PM
Elite Hatch's Avatar
Used motors usually have been sitting in different weather conditions causing moisture to usually end up inside the plugs. Dont worry. Change the plugs if you want let the water dry out of the motor. It should start up make sure the car is getting spark and make sure its getting fuel
Old Sep 9, 2002 | 06:56 PM
Tofurky's Avatar
Default Re: Pulled out spark plug, there was some water.... (Elite Hatch)
the car's not getting spark. we're thinking it's possible it's a bad distributor, or maybe the wiring to the distributor is messed up. we're pretty sure it's not fuel....
still not sure though, why wouldn't it be getting spark?
Old Sep 11, 2002 | 09:46 PM
distributor, wires, cap, ingnitor, ecu, distributor wiring harness
Old Sep 11, 2002 | 10:09 PM
Nameless RB26's Avatar
A good way to get rid of moisture down there is to spray an air hose in it, if you don't have time to sit and wait.
ILOVEGIRLS
Apr 19, 2006 07:52 PM
Sinner
Aug 7, 2005 08:49 PM
boondox_saint
15
Jul 17, 2003 11:16 PM
GrouNDzeRoHYBRIDS
Apr 8, 2003 09:54 AM
Tofurky
Sep 16, 2002 10:06 PM
