Rocker arm installation?
Okay, so I was wondering if it mattered which side the rocker arms are.
Does it matter if the ones that were on the exhaust side are on the intake side?
Because I'm pretty sure I was just being a jackass and didn't keep track of which rocker arms go where....... I have a b18b if it makes any difference.
Any help is appreciated. Thank ya.
Do I need to re-adjust my valves?
I think they don't really matter but somebody should be able to confirm this as I wouldnt like to say,
and it doesnt really harm to check your valve clearances anyway, if their in spec, great and move on to next valve, if their not well good job you checked
Ideally it is a good idea to keep them in the proper sequence and pairs. If that's not possible, reassemble them as best you can and re adjust your valves.
