Which port on motor (F23A1) for oil pressure sensor?
www.stealthmodeperformance.com will allow you to install your gauge and retain the factory oil light.
Tacoma, check out this article from Endyn as well.
Ummm.... 1/8" NPT T-Block with two female ends and one male end. Put the block into your engine, put your aftermarket into one end of the block and factory sending unit in the other, alld one. Not hard and it'll cost you $5.00 in parts.
vladd
Jun 26, 2006 07:18 AM
a1320addict
May 25, 2005 09:20 AM
