Will a bad radiator cap cause a code 6?
Old Mar 17, 2010 | 02:18 PM
wakaranai's Avatar
Default Will a bad radiator cap cause a code 6?
moved.
Old Mar 17, 2010 | 03:28 PM
Singlecam4dr's Avatar
Default Re: Will a bad radiator cap cause a code 6?
maybe a bad temp sensor and tps. i had both two months ago i have a new tps and fixed the wire on my temp sensor. i would check there first and go from there
Old Mar 17, 2010 | 04:28 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
"The weird thing is that my temp gauge works fine.."
The "CTS"= coolant temperature sensor isn't for the gauge..
It's function is to let the ECU know engine coolant temperature
and it then adjusts the fuel mixture accordingly..
When this signal gets altered,the ECU will literally DUMP fuel into the engine..
usually flooding the cylinders and gas-fouling the plugs..
Check the wires and connectors under the distributor
wire colors are red/white and green/white
Check your PM for a link to service manual...
Old Mar 17, 2010 | 05:32 PM
wakaranai's Avatar
Awesome, thanks for the clarification. I was pretty confused about which sensor does what since I read that the ECT is on the back on the block then others said it was on the front under the distributor.
I'll check my PM. Thanks.
Old Mar 17, 2010 | 07:33 PM
brownsEF's Avatar
ihave the same problem cant get rid of that code 6 stumped also
Old Mar 18, 2010 | 01:23 PM
wakaranai's Avatar
Well, that was a waste of $34. The wires to the ECT plug are fine. I purchased a brand new ECT and it made absolutely no difference.
The car continues to run rich and idle bounces like a ****.
The only thing that settles the idle is unplugging the TPS. With the TPS unplugged, the engine idles perfectly.
Also, the ECU is no longer throwing any codes...I guess I'll be testing my TPS and then I'll clean out the IACV.
Old Mar 18, 2010 | 02:12 PM
wakaranai's Avatar
I am really starting to suspect that the tps is bad now. The car runs a MUCH better with the tps unplugged.
Old Mar 18, 2010 | 05:19 PM
wakaranai's Avatar
Just tested my tps.
.719 closed and 4.57 at WOT. its supposed to be at .45 closed right?
Old Mar 19, 2010 | 06:11 PM
Yes roughly mines set at .49 was 60 when I put it in so I adjusted it.
DisplacedMic
Jul 27, 2016 12:33 PM
TNight
Jul 17, 2014 01:20 PM
TcUiRvBiOc
May 26, 2007 03:41 PM
MPALUGHI
Feb 1, 2005 03:53 PM
90 SiR Hatchie
Feb 24, 2004 07:01 AM
