Replacing cam seal/plug
Old Mar 16, 2010 | 05:23 PM
leakysi's Avatar
Default Replacing cam seal/plug
my 00 si is leaking oil.
Checked the dizzy, o ring is good
Replaced the vtec solenoid gasket
And still I have oil, so the only thing left is the cam seal/plug.
Now I have a few quetions.
First, which brand plug to buy, I see multiple when googlin, any recommendations? I know I'm not buying it from Honda.
Second, I found a decent write up on here about it, but it didn't have pictures. I'm certainly not a mechanic, but I'm pretty good with my hands and I like working on my car. But I do a lot better if I have pictures of to go along with the instructions. Any one have a better write up with pictures?
Third, the car has 145k on it and the timing belt was done around 105k. Should I replace the valve cover gasket, or just use some hondabond and call it a day. And does anyone have the torque numbers on the valve cover bolts?
Fourth, if you've read this far, thank you.
Old Mar 16, 2010 | 05:39 PM
itsnotfast's Avatar
Default Re: Replacing cam seal/plug
I've used a blox cam caps before and had no problems. They're like 10 beans on ebay.
Old Mar 16, 2010 | 05:43 PM
757jdmcb7kid's Avatar
Blox x2
Old Mar 16, 2010 | 05:51 PM
HondaPartsHero's Avatar
Technical Hero
http://www.team-integra.net/sections...?ArticleID=576
Old Mar 16, 2010 | 05:56 PM
Ya Digg's Avatar
I would get the gasket set if I were you. torque them to 7.2 pounds.
Old Mar 16, 2010 | 06:31 PM
leakysi's Avatar
Thanks guys
I'll be reading that page(s) for the next couple days while I wait on a plug/seal
Old Mar 17, 2010 | 10:04 PM
BuildTheDream's Avatar
I got S2 because the shop I go to had them in stock, wish I went with blox though. Its basically the same thing but like a third of the price. And personally I would replace the valve cover gasket just to be safe, and they are only like twenty bucks.
speed84
Sep 6, 2007 06:33 PM
worktech
Feb 8, 2006 01:04 PM
mickey513
Aug 8, 2004 06:39 PM
DC2NING
Jun 23, 2004 02:38 PM
Sivicfied
11
Apr 25, 2003 10:32 AM
