Diamond Audio Subwooder/Eclipse amp
I have a 12in Diamond Audio sub in a slot/ported box, paired with an
Eclipse XA1000 amp They sound great together! The amp/sub has been used only a couple times and is basically brand new!
I just don't have a need for them anymore. the amp retails new for $239.99
just need this out of my garage. First $200 takes both! 541-513-6615
* XA Series 1-Channel Class D Car Amplifier
* RMS Power Rating:
o 4 ohms: 320 watts x 1 chan.
o 2 ohms: 480 watts x 1 chan.
* Max power output: 640 watts x 1 chan.
* LED clipping indicator
* Tuned Bass EQ (0-8 dB bass boost)
* Attractive design for practicality and ease of use with all controls such as level, crossover, low frequency boost and high/low pass filter adjustments mounted on the top panel
* Output terminals conveniently located to allow multiple in-line unit installations
* Very high efficiency rate with low current draw
* Gold-plated screw terminals
* RMS Power Rating:
