removing driver side door panel help
so my driver side window will not roll up all the way, once it gets near the top it starts skipping and falling down. i want to remove the door panel because i believe that the window may just be off track, and if i can get it back on with out taking it in i would save a good amount of money.
i am wondering if anyone else has had this problem and know how to go about fixing it. if not then can anyone give me tips on how to remove the door panel with out breaking anything.
thanks for the help.
I believe theirs two or three bolts. One is in the dip for opening and closing the door. The other is behind the handle. Take those out than i believe the rest are just clips you gotta pop off. Those are around the entire pannel
Also in my ek I had to remove the speakers. If you have manual windows take a really small screwdriver and push the clip off that holds on the window handle. Took me forever to figure this out, seperate the panel from the handle a little bit so you can see which way the clip needs to be pushed to come out. Hope this helps
casper.hughes
Oct 12, 2008 06:33 PM
DRAG1320ciVHBKsi
Nov 29, 2002 09:50 AM
Thrillhouse
Apr 14, 2002 11:30 AM
