Flywheel Weight
What is the weight of the stock flywheel?
I found a flywheel on ebay: http://cgi.ebay.com/ebaymotors/LSD-R...#ht_3181wt_841
and a clutch: http://cgi.ebay.com/ebaymotors/ws/eB...ht_3656wt_1166
Do you think this will work ok?
Where can I find a cheap, quality flywheel? How much does Honda charge?
if you pay someone to do this for you expect to sell your legs to pay for it.
its easy do it your self. search around for pics and DIY in the stickies.
buy this
http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
buy this
I found an Exedy Clutch Kit with Flywheel http://cgi.ebay.ca/ws/eBayISAPI.dll?...#ht_2326wt_940
and a XTR Racing Clutch Kit http://cgi.ebay.ca/ws/eBayISAPI.dll?...ht_2573wt_1166
Which one is better? The XTR comes with a 8.5Lb flywheel and can handle 195HP and 181 TQ
I have an XTR Stage 2 clutch and 8.5LB flywheel in my LS and its been fine for 1 1/2 years or so now. I would say that exedy is probably the better brand of the two though.
IIRC my stock D16Z6 flywheel was like 18lbs.
Depends on how the driver is with a manual transmission. I've seen clutches outlast the vehicle as a daily driver, and i've seen them last 6 months as a daliy driver.
Usually clutches need replacing when they start slipping. Try to gently accelerate from a stop in top gear, 5th. If it stalls, clutch is probably ok. If it revs, clutch is on its way out.
I got an exedy clutch kit from these guys a couple of times and all has been good with good prices
http://stores.shop.ebay.ca/gripforce...&submit=Search
m3dia_lab
Sep 28, 2004 03:02 PM
