68mm blox racing throttle body question
Old Mar 15, 2010 | 10:23 PM
93delslow315's Avatar
Default 68mm blox racing throttle body question
i was going to buy this throttle body this Friday but i was curious would this throttle body work with my stock tps sensor?
Old Mar 15, 2010 | 10:25 PM
bluejcivic's Avatar
Default Re: 68mm blox racing throttle body question
it should work fine
Old Mar 15, 2010 | 10:56 PM
BuildTheDream's Avatar
They are designed to be direct replacements/upgrades from the stock ones
Old Mar 16, 2010 | 12:16 AM
Ruben19's Avatar
r you running the stock intake manifold?
Old Mar 23, 2010 | 11:03 AM
na i have an obx intake manifold
Old Mar 23, 2010 | 11:13 AM
deadazleep's Avatar
its a replacement so it should work, just take the one off your old one, put in on the blox and calibrate it and your good to go, make sure the intake manifold is port matched
Old Mar 30, 2010 | 07:56 PM
PtownCivic's Avatar
Do you have to have a upgraded intake? I think so? you want the port hole on your manifold to match the throttle body hole right? i thought about buying the same throttle body......
Old Apr 5, 2010 | 09:14 PM
joel96sedan's Avatar
as stated, its a direct replacement over your stock one, everything should plug right in if its legit. but you must have it port matched, or its pointless pretty much.
Old Apr 6, 2010 | 05:55 AM
TurboTron's Avatar
TPS is already calibrated just put it in right...should fit fine
shahriar35
Jan 31, 2010 12:13 AM
SPD DMN
Apr 12, 2008 08:33 AM
Phatch99
Jun 10, 2004 07:14 AM
J2turbo21
May 17, 2003 09:56 PM
