ECU for Type R in CRX
Old Sep 8, 2002 | 05:23 PM
Lsos's Avatar
Default ECU for Type R in CRX
Let's say I was to put an R motor in my crx. Instead of rewiring the car for OBDII or whatever, is it possible to just plug in the PR3 ecu I have and play it off as if the B18C5 is simply a souped up B16A?
I would probably need to reprogram the ecu somehow. Is it possible to reprogram it such that the engine runs just like stock? How/ who would I go to about doing this?
Old Sep 8, 2002 | 05:27 PM
Kamin's Avatar
Default Re: ECU for Type R in CRX (Lsos)
you can run a b16 ecu but i wouldnt
your best bet is to get your hands on a p28 and have it rechipped to ITR specs.
Old Sep 9, 2002 | 09:29 AM
Trey's Avatar
25 Year Member
Default Re: ECU for Type R in CRX (KAMiN)
Then use your 88-91 harness, add the Vtec wires, and use the OBDO to OBDI ecu harness converter with the chipped P28.
Old Sep 9, 2002 | 09:35 AM
Grimm's Avatar
Default Re: ECU for Type R in CRX (Trey)
why not just buy the r ecu ? rev ta 9k sounds fun to me...
Old Sep 9, 2002 | 11:30 AM
Lsos's Avatar
Default Re: ECU for Type R in CRX (Grimm)
Getting the R ecu would mean an unnecessarily PITA wiring job, from what I understand. As these people are saying, there's easier/ better ways at revving to 9k.
If I was to get the P28, would that result in no knock sensor (I thought I heard this somewhere)? The knock sensor seems important, especially on a motor like the R...
Old Sep 9, 2002 | 12:48 PM
mackymcg's Avatar
I did the wiring for OBDII and the ITR ECU, and it's a bitch to do. And if you have an immobilizer equipped ECU you will also have to get that removed. It is definitely less of a migraine to go with the chipped P28.
I think knock sensor is important, when I first started the motor, I had a honda ECU reader hooked on, and saw the knock sender stayed active for the next two tanks, about a half of tank of 89, then the next tank was 93, and on the 3rd tank, it finally went to normal specs.
Old Sep 9, 2002 | 05:04 PM
dumbchild's Avatar
chip your PR3 with the mugen program - it will bring it up to proper spec - tons of fuel, rev limiter removed, no knock sensor, no secondary 02 sensor.
use your B16 distributor.
Old Sep 9, 2002 | 09:57 PM
RexB16's Avatar
Default Re: ECU for Type R in CRX (dumbchild)
you see guys, the simplest answer is usually the best one. why go thro the hassle of converting anything?
[Modified by RexB16, 10:57 PM 9/9/2002]
Old Sep 9, 2002 | 11:37 PM
JohnBlaze's Avatar
Default Re: ECU for Type R in CRX (RexB16)
i agree with that too
im currently runnin a c5 w/ 12:1 cr with a stock pr3 and 1g b16 injectors. No problems except for low redline and 115governer. but that will change soon. mugen proggy
Old Sep 10, 2002 | 09:36 AM
Lsos's Avatar
Wait a minute....
Is no knock sensor and no rev limiter that good of a thing?
Old Sep 10, 2002 | 01:59 PM
dumbchild's Avatar
it's fine. just be careful.
tit.tea
May 10, 2018 10:10 AM
2000DC2_freak
Jan 31, 2007 04:55 PM
jdmcivicsi7
Jan 13, 2006 09:17 PM
Styler93GSX
Apr 4, 2004 05:49 PM
J sPeC ItR
Dec 1, 2002 06:04 PM
