95 DX crank pulley install
Old Mar 15, 2010 | 09:27 PM
vanilla gorilla's Avatar
Default 95 DX crank pulley install
So I have had problems with crank pulley bolts loosening up and the pulley falling off. Well last time I put the car together I just used red thread locker on the bolt and tightened it as much as I could with a hand ratchet. It was fine for 35k miles, but I just put a new AC compressor on and got the AC working. After I pressurized the system and tested it out, a few miles down the road the crank pulley loosened up and fell off. Im guessing the added stain on the serpentine system from the new compressor made the not-so-tight bolt come loose.
So what do you guys do when you install crank pulleys? Red threadlocker and an Impact?
Thanks for any help in advance.
Old Mar 15, 2010 | 11:28 PM
thumper64's Avatar
Default Re: 95 DX crank pulley install
Get a new bolt and torque it to spec. When you torque a bolt it stretches, or at least should if you don't surpass the elastic limit, which is where it permanently deforms.
Old Mar 17, 2010 | 09:43 AM
How am I supposed to tourque it? If I use a torque wrench how do I keep the engine from turning?
Old Mar 17, 2010 | 09:47 AM
Lanceezy's Avatar
TRIAL USER
I HAD THE SAME issue but had a hard time figuring out
Old Mar 17, 2010 | 10:16 AM
EE_Chris's Avatar
Made by Moroso.
Old Mar 17, 2010 | 10:40 AM
nonvtec92's Avatar
Stick a screw driver in the flywheel teeth... there's a cover with a few bolts in that you can remove and have access to it. Jam a flat head in there so it doesn't spin, get a large torque wrench, possibly with a bar attached if needed, and torque it to proper spec. That's crazy man, torque important bolts like that down! Can't get by guessing with a small ratchet.
Old Mar 17, 2010 | 10:46 AM
h22a4_sol's Avatar
Originally Posted by EE_Chris
Made by Moroso.
if you dont have this tool or dont have money to buy it you can spend about 6.50 at home depot and make one. i made it out of plumbing pipes and its worked for me for about 3years now fits every honda ive worked on and has never broken. a friend of mine had the proper tool and has bought 3 of them in the past year vs my invention 3yrs and hasnt broke stripped nothing has happened to it so i made him one and been great ever since pm me for pics gotta get them out of other computer
bradley
13
Jan 9, 2012 02:12 PM
standy xsi
Dec 2, 2011 04:14 AM
Baron55
Mar 2, 2007 11:00 AM
mike93boost
Apr 1, 2006 03:18 AM
