Detailing Auto Detailing and Concours
Questions about hard water stains on my glass.
Old Mar 15, 2010 | 06:15 PM
vegas's Avatar
Default Questions about hard water stains on my glass.
I recently ran across a steal for a 1990 Integra. A buddy mine had the car for well over 6 years, took good care of it, but the tranny went out and it sat up for about 4 months outside. It sat through winter here in Texas and we saw alot of rain and snow this year. After getting the car I washed it with some dish soap and then waxed it immediately. Paint came out wonderful. Problem is I have these hard water stains in all the glass. As if somebody sprayed soapy water all over the glass and let it dry. I'm at the point where I might try wetsanding or buffing or using some sort of cut and buff.. Any suggestions?
Old Mar 15, 2010 | 07:31 PM
redboost10's Avatar
Default Re: Questions about hard water stains on my glass.
there are many options you can try:
clay bar the windows with some quick detailer
using some polishing compound and a foam pad and da ( i recommend this)
00000 steel wool with some glass polishing liquid.
Old Mar 16, 2010 | 02:34 PM
vegas's Avatar
Thanks for the advice!! I'll give it a try and see what happens..
Old Mar 16, 2010 | 07:14 PM
flip28001's Avatar
TRIAL USER
wet your windows an car spary wheel acid on the window an scrub with a brillo pad. dont let the window or car dry while your doing this,it may take a several trys depening on how bad their spotted.. i detail cars for a living at a dealership for 8 yrs.. i didt believe tell i seen an tryed it
Old Mar 17, 2010 | 07:59 AM
98PAITR's Avatar
There's a product Chemical Guys makes to remove hard water spots. I used it on a friend's car that had concrete water marks in the paint and it worked great.
http://www.detailedimage.com/Chemica...P194/16-oz-S1/
Old Mar 17, 2010 | 08:57 AM
xunsungheroesx's Avatar
You can also try using white vinegar, lemon juice or a toilet bowl cleaner. Hard water stains are actually mineral deposits, which can be removed with an acid. If that doesn't work, take a really close look and make sure that the 'stains' aren't actually pits or craters. In that case you will have to polish or replace the glass.
Old Mar 18, 2010 | 09:03 PM
vegas's Avatar
I ended up taking a slightly used brillo pad out of my kitchen sink and used some rubbing compound and with some elbow grease it cleared up real nice..
TouringAccord
Detailing
Dec 13, 2022 10:38 PM
Michael Bolton
Detailing
Dec 7, 2010 09:03 AM
khronicboy420
Jul 12, 2009 05:42 PM
ferio252
Paint and Body
Feb 2, 2008 06:31 PM
I Want An Si
Jul 22, 2003 08:36 AM
