Questions about hard water stains on my glass.
I recently ran across a steal for a 1990 Integra. A buddy mine had the car for well over 6 years, took good care of it, but the tranny went out and it sat up for about 4 months outside. It sat through winter here in Texas and we saw alot of rain and snow this year. After getting the car I washed it with some dish soap and then waxed it immediately. Paint came out wonderful. Problem is I have these hard water stains in all the glass. As if somebody sprayed soapy water all over the glass and let it dry. I'm at the point where I might try wetsanding or buffing or using some sort of cut and buff.. Any suggestions?
Re: Questions about hard water stains on my glass.
there are many options you can try:
clay bar the windows with some quick detailer using some polishing compound and a foam pad and da ( i recommend this) 00000 steel wool with some glass polishing liquid. |
Originally Posted by redboost10
(Post 41881076)
wet your windows an car spary wheel acid on the window an scrub with a brillo pad. dont let the window or car dry while your doing this,it may take a several trys depening on how bad their spotted.. i detail cars for a living at a dealership for 8 yrs.. i didt believe tell i seen an tryed it
There's a product Chemical Guys makes to remove hard water spots. I used it on a friend's car that had concrete water marks in the paint and it worked great.
http://www.detailedimage.com/Chemica...P194/16-oz-S1/ |
You can also try using white vinegar, lemon juice or a toilet bowl cleaner. Hard water stains are actually mineral deposits, which can be removed with an acid. If that doesn't work, take a really close look and make sure that the 'stains' aren't actually pits or craters. In that case you will have to polish or replace the glass.
I ended up taking a slightly used brillo pad out of my kitchen sink and used some rubbing compound and with some elbow grease it cleared up real nice..
