99 si burnin oil?
Old Mar 15, 2010 | 06:01 PM
lexrob's Avatar
Default 99 si burnin oil?
Ive owned multiple hondas including a 98 prelude and they have all burned about a qrt. every month.
-my new si 130k like a quart every 4 days......
When i hit vtec i get a little black smoke like normal i guess but im a little lost where its going. It blew a 180 comp test pretty much all the way across. I guess i got to do a leak down to check rings? Anyone had same problem valve seals goin maybe?
Old Mar 15, 2010 | 06:16 PM
apexi_rsx's Avatar
Default Re: 99 si burnin oil?
you dont have any other leaks? valvecover? rear main seal? or vtec solenoid?
Old Mar 15, 2010 | 06:34 PM
BryanM.'s Avatar
Resident Gearhead
Leakdown test will not indicate the condition of the oil control rings. FWIW
Old Mar 15, 2010 | 06:58 PM
Ruben19's Avatar
one advice.
DONT HIT VTEC
Old Mar 15, 2010 | 07:29 PM
DVDr's Avatar
Thats alot of oil,
3 main things for leaks.
-something not sealing correctly, ( oil pan, oil pan drain, vtec solenoid,etc)
-Valve seals
-piston rings
Old Mar 16, 2010 | 10:12 AM
lexrob's Avatar
can the vtec solenoid leak internally? =to much oil up in head or (vtec valves???) sumthin along that???
Old Mar 16, 2010 | 12:10 PM
thumper64's Avatar
Even if it leaked like that, it would stay in the motor.
Vtec4me
Aug 4, 2006 06:49 AM
ScoobCivic
Jan 4, 2005 10:14 PM
gsr_to_the_MAX
Oct 19, 2004 11:15 PM
dacaveman
11
Aug 18, 2004 12:49 PM
customx_
Mar 18, 2003 05:56 AM
