ls/vtec options
Old Mar 15, 2010 | 02:25 PM
phelpsj2's Avatar
Default ls/vtec options
i can get a ls block from a friend. i was thinking about getting the ls block, getting a gsr head, and putting higher compression pistons and a gsr crank. i also dotn know if i should do the gsr intake mani or the skunk 2. what are your opinions and inputs? what kinda power do u think i can make. o
Old Mar 15, 2010 | 02:27 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: ls/vtec options
Stick with the LS crank, the LS block is taller than the GS-R block.
Old Mar 15, 2010 | 10:15 PM
BuildTheDream's Avatar
X2 on keeping the ls crank. Definitely get rid of the stock pistons unless you plan on turbo ls/vtec. If the head comes with the gsr intake mani I would just keep that, if not though might as well upgrade while your at it. As far as power goes it depends on what you do to it. Cams, compression ratio of pistons, etc...
egboy94
Sep 2, 2009 03:24 PM
steelies
Aug 23, 2005 06:21 AM
junfanclaw
May 1, 2005 04:45 PM
dc2_and_ef
Feb 12, 2004 04:08 PM
wildstallion
Nov 28, 2002 12:56 PM
