obd2b to obd1 help!!!!
Old Mar 13, 2010 | 04:37 PM
BIGDADDY_STEW's Avatar
TRIAL USER
Default obd2b to obd1 help!!!!
soo i have a 2000 itr and i recently totaled it so ima put my b18c5 in my 93si and i was wondering wat i would need to convert my c5 to obd1? would i jus need the obd1 dizzy and alternator? and injector wires and splice on the obd1 connectors? any input would help thanks
Old Mar 13, 2010 | 05:41 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: obd2b to obd1 help!!!!
yes and yes and if you wanted to
your injector plugs just use a razor and cut the nub off he injector and then itl plug in..
but you should definetly do more searching
Old Mar 13, 2010 | 08:44 PM
94EG8's Avatar
Seagull Management
Use the Integra engine harness and a chipped OBD1 ECU, its that simple.
Old Mar 13, 2010 | 09:27 PM
TRIAL USER
thats what i was guna do in the first place but i tried to jus take out the harness from the motor but a bunch of other wires are in the harness like abs and headlight harness..or would the engine harness plug into the connectors on the shock tower of my eg
Old Mar 13, 2010 | 09:48 PM
boostedcivicsir's Avatar
Mr. Badwrench
the engine harness is completely isolated from the rest. just the plugs at the shock tower, and the other plugs near the master cylinder.
luckily obd1 and 2 dizzys have the same guts basically.
not obd0 and 1? thats where you would need to change.
lejeaune
Apr 21, 2010 09:31 AM
ozrednsx
Dec 13, 2007 10:55 AM
Honda_Fanatic
Oct 29, 2007 08:52 AM
myEK=slow
11
Aug 21, 2006 08:20 PM
E_F_9
Dec 22, 2005 02:26 PM
