Civic VX Re-fresh Ideas...? Input Please
This thread will be a little different from what many are used to. It's mpg and restoration is what i'm after.
Yes, it's time to sink money into my civic that I have sitting around. My goals have changed. I want to keep the D15Z1 and sip on gas. I commute about 30min highway everyday to work, so it makes more sense to keep the car the way it is since it's amazing on gas for highway commuting.
However, it's got nearly 300,000 kms on the engine and trans. But from what I can tell, the car has been driven friendly. Yet, I'd really like to re-freshen it up. I would like to overhaul everything without having to do a rebuild. Here's what I have on mind...
-timing belt
-tensioner
-waterpump
-alternator belt
-radiator (i need a new one)
-plugs, wires, dizzy cap, and rotor
-ignition coil
is there anything that i'm missing?
basically, i want to make it run like new without having to dig into the internals. is that possible?
throw some suggestions out.
thanks
-timing belt
-tensioner
-waterpump
-alternator belt
-ignition coil
thanks
Great to see another VX in Onterrible. I picked one up last summer .. I'm looking forward to swapping its motor into my CX hatch.
Have you been changing your fluids lately? Brake fluid, clutch fluid (mine's filthy), MTF. Do a full coolant flush when you change your rad, but use OEM Honda coolant.
Onterrible. HA! So true.
it's been parked ever since i bought it (last year). i was originally gonna do the whole "supe it up and turbo it" thing. but since my hatch so happens to be a vx model, the thought of getting 50 mpg is very appealing- especially since i commute a lot.
yes, coolant flush is a definite. it's a normal thing to do if i'm replacing the rad. brake fluid and clutch fluid is definitely a good idea. i'm even thinking about replacing the clutch too just for peace of mind.
the car drives fine though (from what i know of). however, i'm just **** about used cars that i don't have previous history about. getting all the maintenance stuff out of the way will just make me feel easier.
i might need to have my fuel lines done... or maybe even a fuel tank. how much do you think that'll cost? everything else i can do myself. i just don't know how to do lines...
From what you listed up top, you're not doing an overhaul so to speak but more like a major service (or 60k service...I don't know, but you get what I mean). Having said that, if there's nothing wrong with the motor then you should be fine with everything you have listed plus new fluids all around. I was like you about 2 years ago, my car being a CX/8valve model. The difference with mine was that it was consuming oil and shooting it out the tailpipe. Instead of swapping I wanted to keep the original motor and the decent MPG. I ended up doing a complete overhaul which added on top of what you're doing a new set of oversized pistons (cylinderwalls were no longer round so machine work was necessary), new bearings, new rings, all new gaskets and seals, literally everything needed for a complete rebuild. I actually lost a couple of MPGs with the end product but there are absolutely no leaks of any kind and no more oil loss. I think with what you have listed you'll be in good shape (that is of course if everything internally is in good shape).
HondaJack
Sep 21, 2006 05:29 PM
tougehonda
Jul 28, 2005 09:25 AM
hott-nix
Feb 24, 2005 08:43 AM
RACING INTEGRATION
Mar 22, 2003 08:16 AM
