Car overheating??
Ok, so I am trying to figure this out, there is no water in the oil. When I ride around the car stays cool, I actually take off in it real good and the car starts overheating and I shut the car off pop the hood and the overflow is filled and squirting water out of the top. I am wondering if the waterpump needs to be changed? I put maybe a quart of water in it and the radiator is full again. Car has a new thermostat and just been put together, has 650 miles on the build. This is getting irritating because I hate when I play with it I have to stop and put water in the car?? Does not smoke and does not skip. There are no check engine lights either. Car is a turbo'd LS/Vtec.
i would check your cooling system first before anything. I hade a hole in the overflow, and it used to over heat like yours. I got a new one, than my car wus doing the same thing, I checked n checked m checked sum more, didn't find anything that could have been wrong. than I noticed that my radiator cap seal wus messed up, allowing pressure to be released, causing the over heating ( wusn't cooling the coolant properly). check your cap and for any small leaks in your radiator
still you would not get a pressurize cooling system within 30 sec.
if u don t have the tool
here s where u can get a cheap one
don t buy a 300 snap-on like me lol.......
http://search.harborfreight.com/cpis...sure&Submit=Go
awesome thanks man. I have a friend that lives about 25 mins from me he has all this stuff, but I need to buy one myself lol.. thank you for the site.
first and foremost ......you need to get a pressure test done on the cooling system and on the radiator cap,...fyi if you running a motor swap and have not changed the radiator to a dual core then you car will overheat due to the fact single core radiators can not efficiently cool down a dual cam motor under load the car will heat up ....
if this was done first then you would have found the B.H.G
masterkill455
May 21, 2009 10:18 PM
.. oh well i've done started to pull the head off, should have it going again tomorrow.
