Car overheating??
Old Mar 13, 2010 | 02:05 PM
iamthefollower's Avatar
Default Car overheating??
Ok, so I am trying to figure this out, there is no water in the oil. When I ride around the car stays cool, I actually take off in it real good and the car starts overheating and I shut the car off pop the hood and the overflow is filled and squirting water out of the top. I am wondering if the waterpump needs to be changed? I put maybe a quart of water in it and the radiator is full again. Car has a new thermostat and just been put together, has 650 miles on the build. This is getting irritating because I hate when I play with it I have to stop and put water in the car?? Does not smoke and does not skip. There are no check engine lights either. Car is a turbo'd LS/Vtec.
Old Mar 13, 2010 | 02:49 PM
ctr32's Avatar
Default Re: Car overheating??
most likely the head gasket or need to resurface your head, same exact thing happend to me.
Old Mar 13, 2010 | 02:51 PM
I thought if a head gasket popped it would smoke or skip or something at least?
Old Mar 13, 2010 | 09:52 PM
bump, anyone have any other ideas?? I was told that maybe my radiator cap is letting air get in. Anybody had that happened before?
Old Mar 14, 2010 | 12:30 AM
rev-speed's Avatar
if the radiator hose builts pressure fast (cylinder head needs to come off-more than likely warp)
Old Mar 14, 2010 | 09:09 AM
but the thing is I don't know why the head woud be warped, I took it right off my b16 and it was fine, put it on this and it started that.
Old Mar 14, 2010 | 09:11 AM
well looks like I may end up just having to take the head off and check it.
Old Mar 14, 2010 | 09:16 AM
civic89efracer's Avatar
i would check your cooling system first before anything. I hade a hole in the overflow, and it used to over heat like yours. I got a new one, than my car wus doing the same thing, I checked n checked m checked sum more, didn't find anything that could have been wrong. than I noticed that my radiator cap seal wus messed up, allowing pressure to be released, causing the over heating ( wusn't cooling the coolant properly). check your cap and for any small leaks in your radiator
Old Mar 14, 2010 | 09:20 AM
rev-speed's Avatar
a warp head maybe fine when its allmotor
in a turbo car problems come-out quick
Old Mar 14, 2010 | 09:24 AM
rev-speed's Avatar
-with a faulty radiator car fluid would come outta the cap or over flow as soon as it warms up
still you would not get a pressurize cooling system within 30 sec.
Old Mar 14, 2010 | 09:30 AM
yeah but the car was turbo'd with the b16 in it too.
Old Mar 14, 2010 | 09:37 AM
rev-speed's Avatar
did u bleed the coolant of air?
have u pressure check ur cooling system?
Old Mar 14, 2010 | 09:40 AM
No i haven't yet, I am going to go and see if I can do this today, I have had to work all week and today was my day off.
Old Mar 14, 2010 | 09:45 AM
rev-speed's Avatar
if u don t have the tool
here s where u can get a cheap one
don t buy a 300 snap-on like me lol.......
http://search.harborfreight.com/cpis...sure&Submit=Go
Old Mar 14, 2010 | 09:54 AM
awesome thanks man. I have a friend that lives about 25 mins from me he has all this stuff, but I need to buy one myself lol.. thank you for the site.
Old Mar 14, 2010 | 06:41 PM
Well come to find out the headgasket is blown .. oh well i've done started to pull the head off, should have it going again tomorrow.
Old Mar 14, 2010 | 07:33 PM
DELSLO94's Avatar
TRIAL USER
first and foremost ......you need to get a pressure test done on the cooling system and on the radiator cap,...fyi if you running a motor swap and have not changed the radiator to a dual core then you car will overheat due to the fact single core radiators can not efficiently cool down a dual cam motor under load the car will heat up ....
if this was done first then you would have found the B.H.G
Old Mar 14, 2010 | 07:50 PM
I did go and have a pressure test done today that's how I found out the headgasket is blown, so I have already got one and am putting it on along with a new waterpump and timing belt. Should have the car going tomorrow. and also I have changed the radiator to work with the dual cam motor.
Old Mar 14, 2010 | 10:42 PM
ctr32's Avatar
nice!!
masterkill455
May 21, 2009 10:18 PM
dragaholic
Mar 13, 2008 09:39 AM
rowo87
Honda Civic (2001 - 2005)
Sep 24, 2007 07:07 AM
alb_accord
Feb 4, 2005 06:22 AM
bumpin_bass
Dec 9, 2002 11:09 PM
