Serious problem need help!
Old Mar 13, 2010 | 12:46 AM
winddraft's Avatar
Default Serious problem need help!
My car won't start! It has no injector pulse. But 5 minutes before that the car starts, run, and drive fine.
What I did was had two injectors unhooked, and all spark boot out. I was doing exhaust gas analyzer and cranked for 15 seconds.
Could it be possible that I fried something while cranking and boot was off?
Old Mar 13, 2010 | 01:21 AM
DCRB's Avatar
Default Re: Serious problem need help!
check the alternator fuse (i believe number 14) on the under dash fuse box. is your CEL on solid, no flashing or anything just solid?
Old Mar 15, 2010 | 01:47 PM
winddraft's Avatar
So I checked all the fuses, all the main fuses, the main relay, the wiring harness, the injector resistor box. And nothing. Everything works. but still no injector pulses.
This happened after I had 4 spark boot out, and 2 injectors unplugged. Then I cranked the engine for 15 seconds.
Hope this help. I can't really think of anything else to check.
CKP, distributor, or ecu is my next thing to check.. Anyone else experience this?
Old Mar 15, 2010 | 02:30 PM
sloweredcivic's Avatar
is the fuel pump priming? sounds like the main relay **** the bed....
brandonEM1
Oct 28, 2014 06:28 AM
AznPrideYo
Oct 18, 2006 12:30 PM
jay-tec
12
Dec 6, 2004 06:28 PM
jumpmann23
22
Aug 4, 2003 05:48 PM
FitCRX
Jan 28, 2003 04:37 PM
