People who have done d15b7 to d16y7 swaps successfully please help
Old Mar 12, 2010 | 10:06 PM
DelSlowmo's Avatar
Default People who have done d15b7 to d16y7 swaps successfully please help
i searched and you guys have done the swap successfully using the odb1 harness, but the problem is i found out the crankshaft sensor from the engine (d16y7 obd2) is needed for my car to start. but the odb1 harness has no where for it to plug in, what did you guys do to make it work?
Old Mar 12, 2010 | 10:11 PM
sohc eg's Avatar
Default Re: People who have done d15b7 to d16y7 swaps successfully please help
it's completely unnecessary as long as you use an obd1 distributor and ecu.
Old Mar 12, 2010 | 10:14 PM
DelSlowmo's Avatar
are you sure? because im getting spark, and have been doing research and people say i need it because we arent getting fuel into the sensors, like it primes but it isnt coming out the headers when i crank the engine over and i read that the crankshaft sensor controls that..
Old Mar 13, 2010 | 05:34 AM
Jockone's Avatar
I bought a 97 with a D16y7 and the wires were cut for the crank sensor and car ran.
The OBD1 ECU is not looking for a crank sensor and if it does not need one then it wont stop the car from running.
Sounds more like a fuel problem.
Old Mar 13, 2010 | 05:40 AM
2point2's Avatar
are you using an OBD1 ecu?
Old Mar 13, 2010 | 11:00 AM
sohc eg's Avatar
I had a d16y7 in my 1994 civic cx and my 1994 civic dx. I am very sure.
beamer
May 21, 2016 07:56 AM
Koofy23
May 11, 2015 05:14 PM
nothing_shocking
Oct 5, 2011 09:00 AM
nels00n
19
Aug 16, 2010 08:04 AM
XMarkGuerillaX
May 2, 2003 01:06 PM
