ITR Swap not making power.....
Old Mar 12, 2010 | 09:55 PM
sloweredcivic's Avatar
Default ITR Swap not making power.....
I haven't actually dyno'd it yet but it just doesn't seem to pull very hard on the top end... When I first put it in I have Neptune RTP and I kept hitting the low cam rev limit 7500 rpm, got frustrated and had a buddy burn me a chip with crome the crome low cam limit is red line. Any ideas as to why its not engaging? Something miniscule I may have over looked, the distrubtor and injectors are from my B16, The VTEC solonoid is from my B16 also.
Old Mar 12, 2010 | 10:03 PM
grog's Avatar
Default Re: ITR Swap not making power.....
So you dont have the correct ecu /maps?
are you getting any CEL codes?
Old Mar 12, 2010 | 10:15 PM
No CEL's the neptune is a P72 starter modified and the crome is labeled stock ITR.
Old Mar 12, 2010 | 10:29 PM
grog's Avatar
from your description it sounds like vtec isn't working, is that whats going on?
Old Mar 13, 2010 | 08:21 AM
Yes that is what I believe to be happening. I have checked and added grounds, switched vtec solonoids.... Still just doesn't seem to be engaging.....
Old Mar 13, 2010 | 08:39 AM
grog's Avatar
chech this thread from the FAQs https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old Mar 13, 2010 | 08:53 AM
But I am not getting a CEL thats whats throwing me off. I am gonna double check everything in that thread thanks!
Old Mar 13, 2010 | 09:03 AM
ef-hatchcrap's Avatar
Do you have sufficient oil pressure to engage vtec? Maybe the oil pump is giving enough pressure
Old Mar 13, 2010 | 09:13 AM
alex_b's Avatar
oil pickup sounds like it may be clogged or blocked. i'd check the oil pump too like ef-hatch mentioned.
Old Mar 13, 2010 | 09:33 AM
thanks for the ideas I am gonna double check the wiring then try and find a oil pressure gauge to check it, i will be pissed if i have to drop the pan since 100 miles ago I just put in Mobil 1..... There goes another 40 bucks!
Old Mar 13, 2010 | 10:40 AM
DCRB's Avatar
if you have a super clean container you can re use the oil... just make sure not to get any dirt into it
Old Mar 14, 2010 | 06:50 AM
Well there is something wrong with my VSS, according to the log its maxing out at 4.375 MPH which was not fast enough to make VTEC engage..... I hate it when you spend so much time going in the wrong direction.
aloha_christian
Apr 7, 2014 07:32 AM
jamesschmidt82
11
May 20, 2013 05:03 PM
97itr86
13
Dec 28, 2010 06:44 AM
93jdmh22a
May 16, 2010 10:52 AM
CRX MASE
Aug 4, 2005 06:20 AM
