Having Trouble...
Old Mar 12, 2010 | 09:24 PM
TeamPrestige's Avatar
Default Having Trouble...
my front stock cambers are giving me problems. i've removed the pin and nut but still cant get it to seperate. i've sprayed it down with some WD-40 and let it sit...banged on the side of it wid a hammer and still nothing. any suggestions. could it be rusted? can i use any tools to split them apart. thanks guys...and girls
-Yoshi-
Old Mar 12, 2010 | 10:11 PM
grog's Avatar
Default Re: Having Trouble...
I'm guessing you mean ball joint???
camber isn't a part its a measurement
"Camber is the angle made by the steering wheel of a wheeled vehicle; specifically, it is the angle between the vertical axis of the wheel and the vertical axis of the vehicle when viewed from the front or rear. It is used in the design of steering and suspension." from wiki
Old Mar 12, 2010 | 10:17 PM
oooh k so...question still stands einstein...how do u remove.
*well divided by the biological fact of my scientific, geographic, mathematical membrane...PSssshhh just help out doode
Old Mar 12, 2010 | 10:24 PM
grog's Avatar
I dont know what your question is.
what are you trying to take apart?
Old Mar 12, 2010 | 10:41 PM
i believe its the ball joint on the top that looks almost like a horseshoe. i cant remove it...i've read that all you have to is hit it on the side and it'll come down. i've tried but no luck.
Old Mar 12, 2010 | 10:53 PM
grog's Avatar
yeah that's the upper ball joint, hit the side of where the ball joint goes through, and use a big hammer if you have one like a 3 or 4 lb hammer
I've personaly never had much luck with that method even with a 4 lb hammer, but other people can do it this way easily.
I use a pitman arm puller,http://www.google.com/products?hl=en...ed=0CBsQzAMwAA it was like $20 and it works great, most auto parts stores have these.
BRN12345
30
May 12, 2008 10:56 PM
EG6R
Aug 13, 2007 06:09 AM
EG6R
Suspension & Brakes
Aug 6, 2007 01:46 PM
BlueShadow
Oct 5, 2005 04:37 PM
vteg
May 22, 2002 06:17 PM
