anybody know how to connect shift light (need help)
idk how a shift light needs to be hooked up. but if its anything like a tach all the wires are in the big connector on the back of the cluster. grab a multi-meter, find a ground, and start probing for RPM and Ignition hots. Searching for wire diagrams is also a good idea, save yourself some hunting.
yeah, there's 3 wire. green one is tach.. is you are having problem finding tach wire-the blue one on the distributor is the tach. might be a blue on the cluster. don;t know. i do it the easy was hook it to the dizzy. the other 2 wires are ground and power.
tyler100
11
Dec 26, 2007 06:33 PM
