Need Help
I have a 96 Accord and I put a 94 H22a in it, the harness is from the f22. I am getting no spark at all. I have replaced my plugs, wires, distributor, cap, and coil. I have the MSD Blaster SS Cap and external coil. Still no spark.
I am not sure if the wrong wires are ran for the distributer. The larger plug is ran dirextly to the ECU, idk if this could be the problem or not. I am completely lost. This is my first Honda and I do body work to begin with so motors are not my thing. Anyone have any ideas what couldbe causing this issue?
What you should've done is just do the simple plug N play with the wiring harness then once you get the car to start up, you can start doing the external coil conversion. Then if the car doesn't start at all after the external coil mod, you know its that.
Double check your ground connectiond. Did you hook up a ground wire coming from the wiring harness to the intake mani located on the driverside? It won't create spark whatsoever if that wire is a tad loose.
SCRUBBAGE2
Apr 17, 2011 11:12 AM
