WTB:96-98 civic engine wiring harness
just like the title says. need a 96-98 harness uncut, preferrably vtec or non vtec.
not looking to spend a ton but let me know what you have.
i think i have an obd2 vtec harness, i pulled it out of a del sol si, thought it would fit my car but i didnt check the injector clips cause im a tard, it was confirmed that the injector clips were obd2, if youd like i can try to email you some pics, its as complete as can be i think, i cut the wires for power doors and such, let me know if you are interested
Yeah send some pictures if you can, my email is nbookbinder@gmail.cm.
What motor is the harness off of?
It sounds like it's not what I need if you were cutting out door wires. Does it terminate with the ecu plug?
the motor is off a single cam del sol, i believe it had vtec, i pulled the entire and i mean the ENTIRE harness out of that thing lol, it was at a local pick and pull, i got the fuse box and everything, it has the engine plugs and the ecu plugs as well, let me try to get some iphone pics for ya
JDCB16Cx
Feb 26, 2007 12:15 PM
