how do i know what axle goes on which side??
Old Sep 8, 2002 | 11:58 AM
takeheed's Avatar
Default how do i know what axle goes on which side??
b16a swap to 90 si . witch axle do i use on the passenger side. one has a bigger rubber thing on the axle
Old Sep 8, 2002 | 12:00 PM
Jared's Avatar
Default Re: how do i know what axle goes on which side?? (adamjoey)
the drivers side inner joint is splined all the way down because it slides into the halfshaft. the passenger side is only splined on the end because it goes into the tranny and through the diff.
Old Sep 8, 2002 | 12:21 PM
takeheed's Avatar
Default Re: how do i know what axle goes on which side?? (Jared)
also not quite sure were the spacer is i have to remove in order to fit my axles?not the dust shield on the knuckle
Old Sep 8, 2002 | 12:27 PM
takeheed's Avatar
i mean i already removed the thing on the back of the knuckle with a scewdriver and im not quite sure what the other thing is that has to be removed, is it in the hub or on the axle itself?
Old Sep 8, 2002 | 02:32 PM
90-CRXSi's Avatar
its on the actual axle, a small black ring in front of the cv boot.
grjr
Aug 23, 2012 04:12 PM
TheEvilBain_TDB
Jun 30, 2009 08:02 PM
stockb18c
Transmission & Drivetrain
Apr 5, 2009 07:50 PM
drudy
Feb 1, 2005 09:09 AM
